851 configuration
Nov 02, 2006 3 Replies
Jump to replies (3)
WIN2KSERVER---Hub---USRouter---Switch---DSRouter---Hub---Workstation
We have setup 2 small LANs on an existing network, one upstairs(USRouter) and one downstairs(DSRouter). USRouter has
192.168.3.0/24 inside and static 10.200.1.28 on WAN. DSRouter has
192.168.9.0/24 inside and static 10.200.1.29 on WAN. Both routers are Cisco 851s. We have put static routes in each router to opposite router's 192 network: ip route 192.168.3.0 255.255.255.0 10.200.1.28 ip route 192.168.9.0 255.255.255.0 10.200.1.29 We can ping from DSRouter to WIN2KSERVER, but not from Workstation. Firewalls have been disabled on all devices to troubleshoot. Workstation cannot get to WINServer. Both routers have very simple config., basically out of the box. Both are NATing. Is there an ACL or something that we are missing? Any help is appreciated. Thanks, Dave.
Hi Dave,
You may wish to investigate the Cisco 851 Config Wizard:
Hope this helps.
Brad Reese Cisco Router Port Matrix
An what route do the workstations have?
NAT?
Best post the whole (sanitised) config.
no usernames/passwords and changed public IP addresses.
I find
sh tech xxxx
where xxxx is a feature that you have but are not using e.g. ospf is very handy since it limits the output of the sh tech but still includes the config with some sanitisation.
