506e 2 interface
Dec 24, 2005 4 Replies
Jump to replies (4)
I have a pix 506e with 2 interface, is there a way to setup interface1 with wan and interface 2 with lan 1 for servers and lan 2 with workstation / corp server.
I guess the on way to get this done with a vlan but my pix only supports 2 interfaces. Anyone have ideals?
You need pixos 6.3(4) or 6.3(5) and a switch with vlan-facility. Then you can create vlans with different securitylevels on the lan-side. bye christoph
If you need access controls between "lan 1" and "lan 2", then you would need to use VLANs on the 506E.
If you do not need access controls between the two lans, and you do not need to be able to have the PIX act as the router between the two lans, and do not need to have the PIX act as the DHCP server for the two lans seperately (two distinct IP ranges), then you can do it.
Well my pix only have license for 2 interface so I could not do a VLAN, but what i did do was a static from tcp 80 xxx.xxx.xxx.23 to
192.168.1.2 80. that worked perfect for anything that was external of my name. but any thing that is internal with my name i haveing issuess getting to it.
ex. if im internal and my workstation ip is 192.168.1.100 and it try to do to a website that is in my domain like
it resolve to my public ip xxx.xxx.xxx.23 but the page number display.
Is there something i need to enable on my pix? or do i need to setup a second dns server just for my internal boxes?
Can you upgrade to PIX 6.3?
If your current DNS server is external, add the 'dns' keyword to the end of your 'static' command.
