1900 Entreprrise
Nov 24, 2005 2 Replies
I'd like to double check my understanding...
The Cisco 1950 can have "Entreprise" software or "Standard"?
The "Standard", does not offer a CLI interface?
Can a "Standard" be upgraded to "Entreprise"
thanks
Pg
1950?? Are you sure about that? Cisco used to offer upgrades to enterprise, but that unit is beyond end of support at this point so I'm not sure. The CLI was a bit different than other CLIs so I'm not sure how much it will buy you.
Hi Pierre,
There was no 1950, I assume you mean either the 1912 (12 ports) or
1924 (24 ports).
No, the "Standard" S/W was menu only (also only Bridge Groups, no VLANS), "Enhanced" S/W offered both Menu and CLI, although be careful with the CLI, it looks anmd handles like IOS but definately has its own... quirks...
Yes, straight S/W "upgrade", no issues, except if I remember correctly a failed "upgrade" usually left the 1900 in an unusable state that could only be corrected by Cisco (or official agent).
However the 1900's are EOL and unsupported so I don't know if there may be licensing issues or not.
Cheers................pk.
