1720 and SDM
Jul 21, 2008 1 Replies
The various Cisco literatures for the C1700 series of routers all seem to say that the 1710 doesn't do SDM but implies all the rest do. For example:
"Security Device Manager (SDM) is not supported on Cisco 1710."
"SDM comes by default with the images that contain security feature sets."
This would seem to make sense because the command set for the 1720 and
1721 are the same and the SDM doesn't need to live on the router.
On the other hand the literature for SDM v2.5 says the supported hardware is:
Cisco 1701 Cisco 1710 Cisco 1711 Cisco 1712 Cisco 1721 Cisco 1751 Cisco 1751-v Cisco 1760 Cisco 1760-v
Note that c1710 is listed as supported. I assume that the 1720 and
1750 work but are not supported.
Anyway does the 1720 and 1750 do or can be made to do SDM? How? What version of IOS is needed?
Thanks
I tried with a 1720 and got the "not supported" error message.
