Routing & ADSL Problem
Feb 20, 2005 1 Replies
Hi Everyone
I've setup a Cisco 2514 running 2 Ether networks. I can ping from both to both, connect to one domain and share all data and peripherals.
My problem is that as soon as I connect to the internet, I loose all comms between networks although computers on the same network can still communicate. Seems that the router just stops routing.
My internet connection is an ADSL running on a WinXP(SP2) PC. Whether I share the connection or not OR turn off the XP firewall or not, the symptoms are the same.
Any help appreciated.
Thanx DoosWyn
could you explain the layout of the network a little more? What plugs into what / what IP ranges you're using. As much info as possible.
Thanks, Paul
