Conduit Size & Cable Fill Capacity
Apr 19, 2004 3 Replies
Jump to replies (3)
Conduit Size & Cable Fill Capacity open original image
Would anyone have a handy chart that shows how much Cat6 or Cat5 cables max can be filled in a conduit of 3", 2", etc....
Here is a conduit fill capacity table you can use:
Has CAT3, CAT5E, CAT6 and CAT3 multipair cables
Good luck!
Dmitri,
This is a great URL. If I want to use RG-6 what size OD should I use in the table? Is there a difference between ordinary RG-6 and the QS kind?
Same questions for fiber, only I don't know enough about fiber to be more specific.
Last question (thanks!): If I wanted to use the "combination" or "bundle" cables that I have read about, where you get say 2 each of RG-6 and Cat 5e in one "package," is this table still good?
This is for a project where I will put in some vertical conduit(s) in my house right now, so I can come along later and do the wiring.
Depends on the manufacturer, and the specific cable type. For instance, Belden 7916A is .298" OD..
If you're putting in conduit to the outlets, I wouldn't bother with the combo cables.. individual cables are going to be less expensive, and you retain more options in deciding what to install in a particular location.
