Howto: X10 lights on conduit boxes for barn
May 28, 2006 4 Replies
Jump to replies (4)
I wanted to use x10 to independently control four 300W Halogen lights on the ceiling of my recently-built barn. I am using gray 3/4" PVC conduit and boxes with wires pulled inside for all wiring in the barn which is unheated thru Vermont winters. I wanted to mount X10 modules right inside each box that the lights mounted on. I looked at using appliance modules, but I would have to make 3 wired connections to the plugs, and find a way to glue or attach the module so that the settings could be changed from outside.
Luckily I found that an X10 SuperSocket module slides nicely right inside the Gray PVC Carlin boxes I am using from Home Depot. Drill two holes, and add a load connection on a plug blade, and you're ready to install. Now I can turn any of the 4 lights on and off from a PalmPad or PowerHome.
How It Worked is shown at
This could also be used with a blank cover, to make a conduit-inline X10 switch.
Any comments, suggestions, pointers to similar stuff appreciated!
Regards, Terry King ...On The Mediterranean in Carthage (Back ...In The Woods In Vermont for the Summer)
Is there a reason you didn't use the in-box modules?
I have used these a few times and they fit very nicely inside standard boxes...
I imagine that it gets pretty cold in that barn in the Vermont winter. Has this system worked reliably during last winter? I don't have any temperature specs for X-10 modules, but I tried a "Socket Rocket" on an outdoor flood light last winter. I worked fine above 45 degrees F. but below that would not turn on.
Bill
I tried to use X-10 lamp modules in my attic in southeast Virginia and they failed to function well in the winter. And we have relatively mild winters here.
------------------- I had good results last Christmas when I visited home and brought the Cabin up from below freezing. As I recall all the X10 stuff worked OK...
I'll report my results THIS Winter.
Thanks for all the comments and suggestions!
