Im having a problem setting up my wireless to allow connection. I had a netgear wgr614 v6 setup and it was working flawlessly. I have two other computers hooked up to the router by cable and they are both working fine and my connection to the internet seems to be working great. I thought I had the wireless set up ok but apparently I am missing something.
I have my settings setup as follows.
Wireless network mode = mixed ssid = whatever i set it as. :) wireless channel 11 ssid broadcast is enabled.
(i have the status: SES Inactive) have no clue what that is.
security is set to wpa personal tkip (shared key) I set on the router and the pc. default group key renewal.
mac filter disabled.
the advanced wireless settings i left all as default.
Its broadcasting the ssid so it appears to be up and running. My laptop has an intel proset/wireless card in it and im using its driver although i have tried to use windows xp's wireless network management to get it working and had no luck with that either. With the intel proset wireless utility, my router shows up but when i hit the (configure) button to set it up for connection it just sits there like its not even trying to connect at all. It doesnt even give me a chance to set it up. My router does however show up in the details menu.
Does anyone have any idea what might be going on??
Sorry this is so long, I just wanted to try to get all of the pertinent information.
TIA.
