Wireless Networking signal boosting to 500 ft
Subject Author Date
signal boosting to 500 ft manfred.schmiemann 02-21-07
Posted by on February 21, 2007, 9:05 am
My neighbour in the Canadian countryside has a Linksys WPC 300N
router. His house is 500 ft from my holiday cottage and he is willing
to share the wireless access with me. Signal is ok up to 200-300 ft
away. How can we extend signal range to my house - mains connection is
possible weatherproof half-way...
Thanks!
Manfred
Posted by Jeff Liebermann on February 21, 2007, 11:33 am
manfred.schmiemann@gmail.com hath wroth:
>router.
The WPC300N is NOT a router.
<http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1144763513196&pagename=Linksys%2FCommon%2FVisitorWrapper>
It's a PCMCIA card for a laptop. You need to know is what your
neighbor is using for a router. The probem is that it's probably the
companion Linksys "Pre-N" router, which does not allow for adding
external antennas. Therefore, the best you can do is a better antenna
on whatever you're using for a radio, and a better location (in a
window) for his wireless router.
If you don't have line of sight, it won't work. You might be able to
install a repeater at midpoint depending on what you have have to work
with. You would still need line of sight between the repeater and
both ends of the link. I've had lousy luck with repeaters, but you
might be able to do better.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by PDA Man on March 1, 2007, 5:39 pm
The unit in question is probably a WRT300N, as Jeff picked up on. I have one
in my hand I just picked up to experiment with. There is not a way to
connect external antennas as Jeed also pointed out. Another router would be
your best start to this project
> Thanks!
> Manfred
Similar ThreadsPosted
signal boosting to 500 ft February 21, 2007, 9:05 am
Boosting Signal December 29, 2007, 12:49 pm
Boosting incoming signal March 19, 2005, 6:34 am
Boosting outgoing signal June 19, 2005, 6:47 pm
Boosting WiFi Signal September 8, 2006, 9:05 am
signal boosting for skype February 18, 2007, 1:26 pm
Boosting wireless signal March 20, 2007, 3:53 pm
Boosting the Signal on a WRT54G November 12, 2007, 2:23 am
Signal boosting Belkin July 1, 2008, 4:48 pm
Signal Boosting with a Hawking HSB1 December 5, 2004, 10:08 pm
range expansion/signal boosting December 22, 2004, 3:59 pm
Help with Boosting wireless router signal October 7, 2005, 9:25 pm
Wireless Signal Boosting from One House to Another June 24, 2008, 11:06 pm
"Boosting" the ability to receive a wireless signal?? August 16, 2006, 12:07 am
Boosting signal for your laptop's internal wireless card thread May 19, 2008, 7:25 pm
