I've been connected to the internet successfully via my linksys WAG354G router for some time now, last night the connect just went dead.
My computer can still connect to the router without any problems, I can still access the setup IP etc, it's just the router that cannot connect to the internet.
I have checked the settings, reset the router, unplugged it etc. The wireless lights and the DSL light come on, but not the internet light.
There is nothing wrong with my ISP, I have rang Orange and they say it is fine, I am able to connect to broadband using my old USB Speedtouch modem.
Any ideas what could be wrong or is the router dead?
I've entered my username and password several times to make sure that it is correct, my username is roonster.wanadoo.co.uk@fs the @fs is required to connect to Orange broadband.
Is there any way to access logs that might tell me what is wrong, I've check the logs from the administration menu but they don't tell me anything...
The router settings as provided by orange, they are identical to what I have entered previously without trouble:
router settings
If you choose to use an Ethernet modem / router, the correct connection settings are:
encapsulation:
PPP over ATM
multiplexing method:
VC-Based
virtual circuit:
VPI=0 VCI=38
modulation:
Multi mode
authentication:
CHAP
Thanks for any help!!
