Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Chris Newton on December 27, 2007, 1:35 pm
Hi all I borrowed a Zyxel NBG334WUK01 Wireless DSL Router for my old laptop last month, it came with a usb adapter as my old laptop was not wi-fi enabled. Anyways it worked fine, and for my 2 bedroom house i seemed to get a good reception all over. So for xmas Santa got me a new laptop with Vista and built in Wi-fi, so not being very adventurous i thought i would buy the same one as i knew it worked. It said on the box that it works with vista but was designed for Xp. Anyways i got it set up and decided not to use the USB adapter as mine has it built in. It worked fine but only in the same room and when i took the laptop down stairs it would not connect and could not even find the network i had just set up. I decided to try the dongle and turn my built in Wi-fi off but that did not work properly as the dongle is not vista compatible. according to the website So basically could it be my built in wi-fi thats not working properly even though its fine if its in the same room as the router? And if i go and buy maybe a g+ as this was a g would this help my built in wi-fi pick it up better, if it has more range. Also if i decide to buy a better router with better range that comes with a usb adapter can i just use this? and will it work ok as long as i dont switch the one on in my computer? Sorry for long thread but i am a newbie to all this and wanted to get all info in. Thanks all Chris ------------------------------------------------------------------------ View this thread: http://www.wirelessforums.org/showthread.php?t=35360 http://www.wirelessforums.org | ||||||||||
Posted by LR on December 27, 2007, 3:39 pm
Please log in for more thread options If you got the G202 as part of the package then the Vista drivers are available. <http://dl01.zyxel.com/DownloadLibary_ShortName/G-202/driver/G-202_2.0.2.5.zip>
If it works then it works, just not very well.
> > So basically could it be my built in wi-fi thats not working properly > even though its fine if its in the same room as the router? Apart from the Laptop what is different in setup from when you had coverage throughout the house with the original, same model router and dongle, equipment? 1.Is the router in the same place with the Antenna pointing in the same direction? 2.Is the Transmit power setting in the router set to 100%? 3.Are you using the same Channel and have you tried a different one? You could try installing this WiFi monitor and see if anyone else is using the same Channel or a nearby one:- http://www.xirrus.com/library/downloads/xirruswifimonitorgadget1.0.zip Guide:- http://www.xirrus.com/library/downloads/xirruswifimonitorgadgetguide1.0.pdf You should also be able to check the signal level of the router at different points in your house. >
> And if i go and buy maybe a g+ as this was a g would this help my built > in wi-fi pick it up better, if it has more range. > > Also if i decide to buy a better router with better range that comes > with a usb adapter can i just use this? and will it work ok as long as i > dont switch the one on in my computer? > > Sorry for long thread but i am a newbie to all this and wanted to get > all info in. > > Thanks all > > Chris > > > ------------------------------------------------------------------------ > View this thread: http://www.wirelessforums.org/showthread.php?t=35360 > http://www.wirelessforums.org > | ||||||||||
| Similar Threads | Posted |
| Needs advice | July 9, 2005, 10:35 pm |
| In need of advice | February 19, 2006, 1:31 pm |
| advice pls | May 1, 2006, 4:26 am |
| i need some advice | July 4, 2007, 7:41 pm |
| PC advice | November 6, 2007, 2:21 pm |
| oh boy i need advice !! | December 27, 2007, 1:35 pm |
| Advice | August 24, 2008, 8:34 pm |
| Beginners advice please... | April 23, 2005, 12:20 am |
| Need some technical advice-- | February 1, 2006, 1:05 pm |
| Need Encryption Set-up Advice | March 19, 2006, 2:52 pm |
| wireless advice | July 19, 2006, 4:30 am |
| Need some informed advice | January 11, 2007, 1:33 pm |
| Looking for advice on wireless set up | January 17, 2008, 8:19 am |
| advice needed | February 11, 2008, 12:59 pm |
| WI-FI SECURITY - Advice From The FBI | May 9, 2008, 4:11 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> for Xp.
> the website
