Hope someone can help. I found out from a previous thread (see below) how to get my 4 ethernet ports working again, which is to go to Lan Connections in my Control Panel and switch the connection type from 'Auto-negotiation' to 10Mb/Half Duplex. When I did that the light of the port that I had plugged my cable suddenly came on.
The problem I am having is that I already have the firmware (1.02.07) that the person in the thread uploaded. So I simply tried to then change it back to 'Auto-negotiation' and the light went out again. I switched the router off and on again between these two steps.
Should I be performing other steps before I switch it back to ''Auto-negotiation' ? If this question has been answered elsewhere I would be very grateful for the link.
Thanks in advance
