Using a Billion Wireless-G router (802.11b/g) with WPA2, how can I tell if there are any intruders accessing the system? The only connected_user info I can find in the router is the DHCP pool.
- posted
13 years ago
Any particular model Billion router? Most of the one's I've seen with a Google search have a built in ADSL modem.
In order to sniff the traffic between the modem and the router, it has to be in two different boxes, not one conglomerated box. As John noted, AirSnare is probably the best for the purpose.
In general, if you're using WPA2 encryption, have a fairly long and messy pass phrase, and change it occasionally, you're probably not going to have any hackers on your system.
