hi all .. i have spent the last 5 hrs trying to setup wep security. my laptop is a dell inspiron 700m with an on-board intel 2200bg wireless adapter. the router is a belkin 802.11b wireless/4 port, model # is F5D6231-4_v2. running win xp, sp2
i have done the same steps over and over and even gone thru many help forums but i cannot find a solution to my unique problem.
i connect wirelessly to the router. factory default settings. i go to the encryption settings and there are 5 options (disable, 64 manual, 64 auto, 128 manual, 128 auto) the difference between what i see and what the manual says is that when i write a passphrase (64 auto or 128 auto) i do not see any keys being generated. the boxes where hex keys should have been visible are all greyed out. so the only option is to enter a key manually
then i go to wireless network properties, select my ssid, click on properties->association, select open and wep, uncheck "setup the key automatically" and then enter my key
the wireless network is disconnected. however when i do a site survey my ssid still shows as an unsecured wireless network. if i go back to the wireless properties ->association the settings are back to open and disabled
when i login back to my router ( i was disconnected earlier), the encryption is back to disabled.
this is truly bizzare. i am ready to toss the belkin router since i think it is the problem
tia
-S
