I was helping a friend setting a brand new wireless router (Linksys WRT54GS) and her desktop now is able to connect to the internet. I enabled WEP. On the same wizard, we select the option of adding a wireless computer, which then asked if we have a extra cable or a USB memory device. Unfortunately, since I am not at home, we have neither. So it directed me to print the automatically generated pass phrase and 128-bit WEP key.
Moving to the laptop, I brought up the wireless network connectiion panel. It saw the network which says secured access. I then clicked "Connect", and it asked for the key. I dutifully entered that long sequence (in both boxes). Soon enough, it says connected, single strength = maximum (all green).
I then launch IE, and it was NOT able to get to the internet. Oh, I also try rebooting the laptop and retry. Same result. Is there anything else I should have done? I don't recall if the router DHCP provided an IP to the laptop or not. I'd think so since it did says connected.
Later I did change the router username and password too, in case you're wondering.
BTW, I am also baffled by something else remotely related to the above problem: when you see a secured network, I click connect, put in a random WEP key, say, 1234567890 (twice), and it would show that I am connected with strong signal, but I am then unable to beyond that point. Why would I be conncted to it when I really have given it the wrong key? Try that yourself.
