Problem: When I disable Broadcast SSID my laptop cannot find the network. As long as
broadcast SSID is enabled it works OK.
Router COnfig: Linksys BEFW11S4 Version 4 Firmware 1.52.02 (most currennt) Wireless: Enabled
BASIC WIRELES SETUP TAB SSID: I created a unique ID Wireless Channel: 11 Wireless SSID Broadcast: Disabled
WIRELESS SECURITY TAB Wireless Security: Enabled Security Mode: WPA Pre-Shared Key Group Key Renewal: 3600
WIRELESS NETWORK ACCESS TAD Wireless Network Access: Allow all (I plan to enable MAC filtering once I get this to work)
ADVANCED WIRELESS SETTINGS TAB Basic rate: 1-2-4-11 Mbps Control TX Rate: 1-2-4-11 Mbps Preamble Type: Long preamble Authentication: Auto )Default) Antenna Selection: Diversity (Default) Beacon INterval: 50 DTIM INterval: 1 Fragmentation Interval: 2346 RTS THreshold: 2432
Laptop Windows XP SP2
Linksys WPC11 Version 4 NIC Driver Version : 5.158.1001.2003
