Hello,
I'm using a Bluetooth USB dongle (Kensington BT 2.0 with latest available Widcomm software) with a Plantronics 320 Bluetooth headset and a Iogear Bluetooth GME225 mini-mouse. I did verify Widcomm drivers were running, not Windows drivers.
The headset always works ok. However when the headset is connected and I'm chatting, the mouse cursor has a hard time and is somewhat erratic. I'm quite new to Bluetooth stuff but I always thought no interference should be possible betwwen any of the seven possible Bluetooth devices that can connect at the same time.
Is there anything to do to cure this annoyance? Suggestions?
Thanks! Dan
