Access Point
Threaded View
I'm wondering if an access point would be the way to go here in the office.
Right now I have a linksys 802.11b wireless cable/dls router/4 port hub. And
I have the DHCP disabled. Basically using it for an access point. But it is
old. WEP and no WPA.  No new bios updates since 2002. As of right now, we
manually assign ip addresses to the workstations. Our sonic firewall/router
also has the DHCP disabled. And we are running NT Server 2003. So would a
simple access point be all I would need? I am looking at the linksys Wap54G.
I would assign it an ip address, subnet mask and gateway address. And that
should be it?
I've read that WPA is much better than WEP.
Re: Access Point
Greg wrote:
I hear that using static IP(s) is a tremendous Admin burden and it is better
to use DHCP IP(s). I don't agree with it myself. But how is that working
out for you on the Admin part? Is the Admin part of assigning IP(s) a
tremendous burden for you? It never was for me in my little set-up.
Have you looked at the price difference between a G router that can be
converted into a AP, which I have taken the 11S4W router and converted it
into a switch and connected it to my WatchGuard as opposed to the cost of a
stand alone WAP device.
I have never used a standalone WAP device, but I would think it would have
some better features in the area of security than a router converted to a
switch. I myself would choose a standalone WAP in a business situation
myself if I had to choose between the two.
And WPA is suppose to be a better wireless encryption technology than WEP.
Duane :)
Re: Access Point
Correct.  Wep gets broken in a matter of minutes.  Choose a strong
passphrase for WPA such as
xY%5u*2$h!d$f"h#K@=]H7F8%*n
Re: Access Point
What makes that a strong passphrase?  Do you _know_ it is, or is that a
guess?
derek
Re: Access Point
Taking a moment's reflection, Derek Broughton mused:
| a guess?
    It could be a bit longer ... but it's stronger than "pencil"   ;-)
Re: Access Point
I got bored! :)
Trouble with strong passphrases is that they're incompatible with
humans.
David.
Re: Access Point
Stronger = longer.
Stronger = more random (less guessable).
Re: Access Point
I know that, but the question was really meant to ask if it was stronger
because David "felt" it was stronger, or if there was some provable reason
that it was stronger.  Essentially, other than trying to use things that
can't be found in a dictionary or well-know book, I haven't ever seen a
discussion of _how_ to make a strong passphrase.  In particular, I somehow
doubt that the average human is really capable of making a string "more
random" (though we're all pretty good at longer :-) )
derek
Re: Access Point
Well, I'm no mathematician; but it seems to me that randomness
essentially equates to patternlessness for a finite string of
characters. You can prove that a string has a pattern by finding the
formula for the pattern, but I don't know if there's a formal way to
prove that a given string *doesn't* have an undiscovered pattern.
In any case, you're playing the odds when you use passwords and other
combination locks. There's at least some chance that an attacker will
guess even a very long and patternless password on the first try. All
you can do is make it less likely by avoiding known strings, including
known nonsense like "supercalifragilisticexpealidocious".
There's a lot of software that generates passwords. The products are the
result of a mechanical process, of course, so they're not truly
"random"; but they're more patternless than the strings humans tend to
generate.
Re: Access Point
Well, makes some sense, maybe:
http://www.askfactmaster.com/dict-en/Supercalifragilisticexpialidocious
  All
Re: Access Point
http://www.google.co.uk/search ?
hl=en&q=security+passphrase++entropy&meta=
Re: Access Point
In this case, one that isn't likely to be found in a dictionary or one
that will take computationally too long to brute force crack.  If you
want get into statistical analysis of chosen characters then that's
another matter altogether.
David.
Re: Access Point
On Thu, 11 Aug 2005 15:49:19 -0300, Derek Broughton
I keep an old church hymn book in my office and use it to compose
my passphrase. I choose an old familiar song, then use the page
number, the hymn number and the first letter from each word in
the first two lines of the song. This is easy to remember, but
should be nearly impossible for anyone to break.
Re: Access Point
LOL, after all this time, we're still having a hard time making a cipher
Julius Caesar wouldn't have understood (because, as David said, strong
passphrases are incompatible with humans).
derek
Site Timeline
