Hi, I've recently moved into a duplex apartment and I would like to put ethernet ports into 2 rooms and have the backplane be 802.11g (or preferably n or mimo, or even a proprietary 108mbps connection). However, none of the wireless 4-port routers I've seen bridge. All I've seen are expensive bridging APs that you slap onto switches. I think the multiple boxes thing is aesthetically unpleasing, and I would like to just have one box that does it all on each floor. So the question is, which 4-port wireless routers can bridge? I have found none so far. I may just end up getting the damn APs and switches, the combo price is not that much more than the routers given how cheap switches have gotten, but it just means more wall warts and it's unpleasant to my sensibilities. OTOH upgrading the 'backplane' means not having to throw the switch away...
TIA,
- Matt
