connect 5 points via wireless APs
May 01, 2006 7 Replies
Jump to replies (7)
hi all, i need to create a small wireless lan like this
pc1 - - - pc2 - - - pc3 - - - pc4 --- pc6 i pc5
- every pc is in a different building
- every building is about 400 meters from his nearest neighbour
- i tested the various wireless links (with an AP and a usb wireless dongle, plus homebuilt antennas) and they work well (48 mbps, FTP transfer rate about 2000KBsec )
- i cant use usb dongles in the project, just APs.
THE QUESTION IS : how many AP do i need? what speed can i achieve from pc1 to pc6?
(THANKS!!) :)
Depends on whether a given antenna can cover more than one building.
From your diagram I'd say: pc1: USB dongle to pc2 pc2: At least two access points, client bridge to pc3, and host for pc1 and pc5 if one antenna works, otherwise separate hosts for pc1 and pc5 pc3: Host access point for pc2, and client bridge to pc4 pc4: Host access point for pc3, and client bridge to pc6 pc5: USB dongle to pc2 pc6: Master access point for pc4 and all others through pc4
If done properly, the speed of the slowest intervening link, other wireless traffic permitting.
thanks for fast replying :)) pc2 can cover 2 buildings (1 and 3) with one AP, by putting 2 directional antennas on it .
as told before , i can't use usb dongles in this project. Just APs. :(
in other words, wireless bridging itself does not interfere in speed, am i right?
marco
Just out of curiosity, any cables/conduits between buildings? Did that on my ranch in idaho (house/garage/barn/guest house), had multi-conductor cables (for phone, network, intercom, cable tv etc) and electrical cables between em, just used multiple ap's, all with the same ssid, connected over 4 of the
20 conductors in the underground cable. Lets me wander around the 20 acres with my wireless notebooks and pda's.
PS, wireless bridging will interfere with the speed, wired didn't, and the bonus was having the cables underground when bad weather hit.
Are you sure? If so, then.
Sorry -- misread that. Then: pc1: Client bridge to pc2 pc2: Client bridge to pc3, and host access point for pc1 and pc5 pc3: Host access point for pc2, and client bridge to pc4 pc4: Host access point for pc3, and client bridge to pc6 pc5: Client bridge to pc2 pc6: Master access point for pc4
Right *if* there is no interference between the various legs, by means of directional antennas and/or non-overlapping channels (1, 6, 11).
Wireless *bridging* with two access points won't interfere with speed if the two wireless legs are non-interfering, by means of directional antennas or non-overlapping channels (1, 6, 11). Perhaps you're thinking of wireless
*repeating*, which does interfere with speed.
john Navas replied:
so the answer is pc1: 1 AP (Client bridge to pc2) pc2: 2 (Client bridge to pc3, and host ap for pc1 and pc5) pc3: 2 (Host access point for pc2, and client bridge to pc4) pc4: 2 (Host access point for pc3, and client bridge to pc6) pc5: 1 (Client bridge to pc2) pc6: 1 (Master access point for pc4) TOTAL : 9 APs
thanks!!!
Not necessarily. An access point isn't necessarily usable as a client bridge. You need to be sure that you can configure them as needed.
