I know of a feature that when you want incoming calls forwarded to let's say your cellular you can reconfigure the office phone. However you have to be onsite to do so. But what if you can't get to the phone. Is there a way of doing this remotely or is there some kind of auto call forward feature so that if line goes down the system automatically forwards incoming calls to the cellular.
[TELECOM Digest Editor's Note: You did not say what is your telco in your community, but many/most telcos offer a version of 'remote call forwarding' which allows you to call into a specified number and then enter a password followed by _the number you wish to forward_ and give it the usual *72/*73 commands at that point. To prevent others from forwarding (or turning off the forwarding) against your will it is passworded. The number you dial into may or may not be on the same exchange as your number, but it is on the _same switch or ESS machine._ The number you dial into is sort of a 'terminal' (like a central office technican would use in the office) to deal with your phone remotely. But it is very limited in its command set; you can do *72 or *73 (whatever code turns on and off call forwarding) and not much else. I used to have that on my Illinois Bell line in Chicago. The idea is that people leave home, _then_ discover they forgot to forward their phone. I think when I lived in Chicago I dialed something like 312-334-9995 or similar, but no where close to my own number. After a ring or two and a click it answered by asking for 'my number' (and then upon entering same) it asked for 'password' and upon getting that it asked for 'command?' I could enter *72 or *73 (which in Chicago in those days was turn on/off call fowarding) and in the case of *72 the number to which calls were to be forwarded, ten-digit format. It then quoted back audibly what it had done, asked for approval, and disconnected. Other 'star commands' (*60 *67, *71, *77, etc) were ignored.I do not think it was called 'remote call forwarding' since that is the name of the service set up to automatically forward your calls to some long distance point. Perhaps it was 'remote forwarding' (without the word 'call'). You would have to ask around. If you have two actual phone lines and numbers (not just a virtual number like 'call waiting') I think you can now purchase (
