All,
Ive read a lot of discussion on this about wireless v wired burglar alarms but I think I need a combination of the 2. I dont seem to be able to find a system that quite matches my requirements. I will be fitting the alarm myself so it needs to be relatively simple, though Im not a complete numpty.
My home is new build so it has the cabling in place for 4 PIR's, there is a blanking plate in the hall for a key pad, a blanking plate in a cupboard where I suppose the main controller goes, there is also a cable going to an outside wall for the bell. Now typically this would be quite a simple installation I imagine, however, I also have a garage which is detached from the house which I would also like to be alarmed from the same unit. What Im looking for I suppose is a system that I can use wired for the wired PIR's in the house, but also use a wireless connection to whatever is in the garage. The thing is, I would want the wireless connection to the main unit to come from a mains powered PIR (or door sensor) rather than a battery powered one since I dont want to be changing batteries all the time. The garage is only a few feet from the house.
The other thing is that its a double garage so would you recommend door sensors or just a PIR, or more than 1 PIR? I'd also like that sensor to be able to chime when its activated.
And finally (news at ten moment) how difficult / complex is it to get the alarm to phone you when it goes off?
I know that Im asking for the moon on a stick here, but I dont want to buy a half way solution thats not what I want. What can you recommend anything for all of this?
Thanks
Rod
