Carrying CCTV signal over house wiring using Homeplug
Jan 13, 2008 1 Replies
Would it be possible to run a CCTV signal over the house wiring using a Homeplug. Say got 2 BNC to RJ45 balun adapter - put CCTV on adapter and then run CAT5 cable from adapter to Homeplug. At the other end would be another Homeplug, CAT5 cable going to another adapter and then BNC connected to recording device. (PC, VCR, whatever).
No, not as you have described. Homeplug carries ethernet, and the BNC to RJ45 balun adapter does not create ethernet frames.
