Any Notifier experts here? I need to know what the right 2 led's on the power supply are. The pannel is an AFP 400 and the power supply is on an XP Transponder. I think the LED's are + and - ground fault they are LEDs 4 and
- I have an intermitant trouble on this transponder that shows short circuit. What would the system be monitoring for a short circuit? I have tested all the horn loops out of the transponder and cannot find a short "positive to negative".
Also it shows an invalid reply on a different transponder, when I reset the panel the transponder will work for about 5 minutes then it goes back to trouble with an invalid reply. During the panel reset the LED's on the transponder lite up so I am fairly sure the thing is talking with the panel. What would cause an invalid reply? On the addressable loop that goes to this transponder I have noticed the shield is not grounded. When I tried to ground the shield, every device on the loop gave me an invalid reply trouble. I measured the shield to the other loop wires but dont show any kind of short. Any Ideas?
James B Denco Security Inc.
