I know this topic has been flogged to death, but here goes.
I've had some x10 gear for a few years. As everyone knows, it's not very reliable. I've spent some time experimenting and debugging, trying to improve the performance. Unfortunately, however much I twiddle with filters and what-not, it's never very reliable.
I realized a few months ago exactly why that is. The fundamental problem with the notion of fiddling with x10 filters, boosters, and meters "until it works" is that it imagines the home power distribution network as something that is static, or nearly static. If it's static, you identify the noise sources, the signal sinks, and what-not, and you compensate. But this doesn't really work.
It doesn't work because the power network changes constantly. As a typical American household we have dozens of electronic appliances, and things get plugged and unplugged every day. Laptops, shavers, mixers, toy ovens, vacuums. Electronic items get purchased and sold regularly. Every day, at any moment, in any room, on any circuit with outlets, someone may plug in a laptop, or a vacuum, or a boombox, or a baby monitor, or who knows what, and abruptly the x10 signal distribution has changed. Some light switch stops working. Why? Well.. that could take hours to debug. And the solution doesn't generalize. It doesn't prevent the NEXT signal failure, when someone plugs something else in on a different circuit. It may even depend on permutations, like a boombox here and a noisy ballast there. There are literally thousands of permutations of things plugged in and things turned on, any number of which may disrupt x10 signalling.
SO... my question: To the people who seem to be reasonably successful with tweaking this stuff (I'm thinking of Jeff Volp and others), how do you deal with this? Do you carefully monitor what gets plugged in? Do you live alone, as opposed to in a house with several other people who might plug things in? Is there some other secret to tweaking x10 so it works even when six different things are plugged in over the course of a day?
I just saw the XTB page for the first time, and all the gushing reviews about how this solves everything, or nearly everything. On closer inspection, though, it seems to more or less confirm that power line transmission basically doesn't work. The XTB boosts the power of an RF transponder. So to build out with XTB, you basically have to move everything to RF. It doesn't help with other x10 signal sources, like wired controllers. And, if you have several plug-in x10 signal sources, you need an XTB, at $80, for each one. So you really do have to move everything to RF, or dump $80 more for every device that's going to generate x10 signals (in which case you could spend it on some higher-end technology instead of x10).
Unfortunately, RF isn't a great choice for me either, because metal lathe in some of the walls leaves RF shadows around the house.
