General Home Automation x10 switch problem?
Subject Author Date
x10 switch problem? Amadeus W.M. 02-09-08
Posted by Amadeus W.M. on February 9, 2008, 6:03 pm
I have a wall motion sensor switch that I've been using happily for some
2 years now. It controls the ceiling fixture which up until today was a
ceiling fan that came with the house.
Today I took the fan off and I installed a new fixture. It uses a 30W
fluorescent ring bulb. The light is off when the switch is off, it's on
(and steady) when the switch is on, but it flickers continuously when the
switch is in the middle (i.e. set to motion detection). Is this normal?
Must I have an incandescent bulb with that switch?
I installed the switch and the light fixture, so I may have done
something wrong, but so far nothing has blown up yet.
Posted by bruceR on February 9, 2008, 6:54 pm
> some 2 years now. It controls the ceiling fixture which up until
> today was a ceiling fan that came with the house.
> on (and steady) when the switch is on, but it flickers continuously
> when the switch is in the middle (i.e. set to motion detection). Is
> this normal? Must I have an incandescent bulb with that switch?
If you inspect the switch I suspect that you'll find an admonishment like
"For Incandescent Use Only" so you'll have to replace it or the bulb.
Posted by Amadeus W.M. on February 9, 2008, 8:07 pm
> like "For Incandescent Use Only" so you'll have to replace it or the
> bulb.
Would I have the same problem if I replaced the switch with an X10
switch? Does x10 work at all with fluorescent lights?
Posted by bruceR on February 9, 2008, 9:58 pm
>> bulb.
You'll need to use the "Appliance" model with the relay inside.
Similar ThreadsPosted
x10 switch problem? February 9, 2008, 6:03 pm
Strange problem with X10 wall switch August 24, 2005, 11:02 pm
X10 problem April 11, 2005, 3:10 pm
Here's a New Problem for Me... March 21, 2006, 12:47 pm
odd problem, odd fix September 23, 2006, 8:53 pm
The problem with HA November 6, 2006, 4:27 pm
Problem with CM11 March 11, 2005, 11:13 am
TM751 Problem November 3, 2005, 10:06 pm
HCM06 Problem January 2, 2006, 10:12 am
XP Chkdsk Problem May 4, 2006, 5:47 pm
LM14A problem May 30, 2006, 10:35 am
X10 collision problem June 14, 2006, 6:51 am
Help! Strange X-10 Problem August 28, 2008, 10:19 am
SmartHome SwitchLink Problem March 5, 2005, 2:20 pm
Problem with cheap video cam April 12, 2005, 12:45 pm
