Hi
I live in a late Victorian house with some oddly placed light switches. I'd like to "move" a light switch without having to chase cable from the (newly decorated!) room so that I can resite the switch on the opposite side of the room.
I'm imagining a product which has an RF receiver in place of the old switch and then a battery operated new switch which I can just attach on the wall where I want the new switch.
I've run up against a couple of problems:-
1 - I can't find such a product! 2 - I have a halogen light fitting with a 12v transformer as the lighting in the room.Changing the light fitting for a "normal" on is certainly an option, so I'm left with problem 1. Even an IR unit would be OK-ish if I could find one that had a stick on switch instead of a remote-control sytle switch.
X10 looks fun (ish!) if someone could point me in the right direction to start with. I've seen a switch (AW10U) which seems part of the answer, so if someone could let me know what I would need to pair this with to create a working scenario I'd be grateful.
I've googled for many an hour without coming up with the right answer!
btw, I'm in the UK if that helps.
TIA!
Matt
