I have a Sony 100W A/V receiver. I recently bought a Phoenix gold ISM6 speaker distribution panel that I want to use to add speakers in the basement and outside all running from the single source receiver. My setup is as follows: Front L/R speakers cable goes to the input on the ISM6. Output from ISM6 goes to the front L/R speakers. Zone one from the ISM goest to the AMP side of the impedance matching volume control. Speaker cable is run from the speaker side of the volume control to the speakers themselves. Should this scenario work without issue? With the current setup if I select zone 1 on the distribution panel and then turn on the volume control I do hear music from the speakers but regardless of how high I turn the volume control it never gets any louder. Should the volume off zone 1 be similar to that of the speakers directly connected to the receiver. It doesn't even come close to what I think it should be. What could be wrong with my setup? There are no jumpers on the volume control it says it automatically detects the necessary settings.
Kooch54...
