~ On Mar 26, 3:42 pm, Aaron Leonard wrote: ~ > Then look at co-channel interference, noise, etc. Make sure that ~ > things look pretty solid.
~ Thanks everyone for the information and links... I have one more ~ question: How do I look at the co-channel interference and noise? Do I ~ need a spectrum analyzer?
Co-channel interference refers to multiple 802.11 cells (i.e. BSSIDs AKA APs) overlapping in the same physical space. So as a first cut, you can just use your site survey tool (whatever it may be) and see what APs are present (at what signal levels) at each physical point in your coverage area.
For example, let's say that you see the following APs:
On channel 1: AP1 @ -55dBm, AP2 @ -88, AP3 @ -89 On channel 6: AP4 @ -72dBm, AP5 @ -86 On channel 11: AP6 @ -53dBm, AP7 @ -84
Then I would say that you're fine wrt co-channel - a client in that location should pick either AP1 or AP6, and any other APs on that channel are
30 dB away.
On the other hand, if you have:
Channel 1: AP1 @ -55dBm, AP2 @ -65, AP3 @ -70 Channel 6: AP4 @ -60dBm, AP5 @ -63 Channel 11: AP6 @ -58, AP7 @ -63
Then you have a co-channel problem - no matter whether the client picks AP1, AP4 or AP6, there is another AP within 10 dB.
Now, with co-channel interference, you don't necessarily see any performance problem, until you get under load. To measure the load effect, you really would need a packet capture tool or similar at the time of load.
Noise, on the other hand, is non-802.11 energy. (Or what is *perceived* as non-802.11 energy by the 802.11 radios - it could actually be energy from some distant AP, or from an AP on an overlapping channel [like from channel 3 when you're on channel 1.]) You would use a spectrum analyzer (like Cisco Spectrum Expert) to measure noise.
Having said all of the above ... you can also just look at your lightweight APs to measure the "load" (i.e. 802.11 interference, from this/other APs in your RF group), "interference" (i.e. 802.11 interference from other devices *not* in your RF group) and "noise".
Example (from my lab):
(WLC4402) >show ap auto-rf 802.11b AP1142
Noise Information Noise Profile................................ PASSED Channel 1.................................... -93 dBm Channel 2.................................... -90 dBm Channel 3.................................... -81 dBm Channel 4.................................... -94 dBm Channel 5.................................... -59 dBm Channel 6.................................... -92 dBm Channel 7.................................... -89 dBm Channel 8.................................... -90 dBm Channel 9.................................... -87 dBm Channel 10................................... -90 dBm Channel 11................................... -94 dBm Interference Information Interference Profile......................... FAILED Channel 1.................................... -70 dBm @ 2 % busy Channel 2.................................... -128 dBm @ 0 % busy Channel 3.................................... -46 dBm @ 12 % busy Channel 4.................................... -39 dBm @ 2 % busy Channel 5.................................... -128 dBm @ 0 % busy Channel 6.................................... -128 dBm @ 0 % busy Channel 7.................................... -128 dBm @ 0 % busy Channel 8.................................... -128 dBm @ 0 % busy Channel 9.................................... -56 dBm @ 1 % busy Channel 10................................... -128 dBm @ 0 % busy Channel 11................................... -44 dBm @ 23 % busy Load Information Load Profile................................. PASSED Receive Utilization.......................... 0 % Transmit Utilization......................... 1 % Channel Utilization.......................... 29 % Attached Clients............................. 1 clients [ ... ] Nearby APs AP 00:12:44:b3:e0:00 slot 0.................. -8 dBm on 1 (10.0.47.3) AP 00:19:07:c6:04:b0 slot 0.................. -22 dBm on 11 (10.0.47.11) Radar Information Channel Assignment Information Current Channel Average Energy............... -60 dBm Previous Channel Average Energy.............. -18 dBm Channel Change Count......................... 96 Last Channel Change Time..................... Thu Apr 1 05:44:27 2010 Recommended Best Channel..................... 11 So this shows some real concerns:
- noise at -59 dBm on channel 5
- high interference on channels 1, 3, 4, 9 and 11
- potentially high load (29%) on your channel (11)
- APs excessively nearby (-8 and -22 dBm - they're all in the same rack actually)
- previous channel average energy -18dBm (that's super loud)
- 96 channel changes
If this were a real production network, rather than just in my messed-up lab, I'd be worried ...
Hth,
Aaron
