hi I just configure this network
R3--R1--R4
and these are the conf
hostname R3 ! interface Serial0 ip address 10.1.1.3 255.255.255.0 encapsulation frame-relay ip ospf network non-broadcast ip ospf priority 0 ! router ospf 1 log-adjacency-changes network 10.1.1.0 0.0.0.255 area 0
hostname R1 ! interface Serial0 ip address 10.1.1.1 255.255.255.0 encapsulation frame-relay ip ospf network non-broadcast ip ospf priority 1 ! router ospf 1 log-adjacency-changes network 10.1.1.0 0.0.0.255 area 0
hostname R4 ! interface Serial0 ip address 10.1.1.4 255.255.255.0 encapsulation frame-relay ip ospf network non-broadcast ip ospf priority 0 ! router ospf 1 log-adjacency-changes network 10.1.1.0 0.0.0.255 area 0
Result R3 can ping R1 but not to R4 and vice versa. R1 can ping anywhere.
I know that I should use ptp or ptm, I just want to see how it works using non-broadcast mode with 'ip ospf priority' command.
If it won't work, why? If it works, how and why?
