Hello Is it possible to do VLAN Translation on a VLAN which has dot1q tunnel ports? I mean that suppose I have a customer facing port, GigabitEthernet5/1, and I make this a dot1q tunnel port and assign it to VLAN 200. So now the VLAN 200 carries double tagged frames. I also have a trunk port called GigabitEthernet6/3, in the same network, which is a core trunk port which is on VLAN 200. On this port, I want to translate VLAN 200 to VLAN 300. Is this possible? I am using a Cisco Catalyst 6509 with IOS 12.2SX Please send example commands if possible. Thank you for your help!!!
Maya
