Now with pictures!
Subject
- Posted on
Basic CDP question..
- 01-10-2008
January 10, 2008, 3:00 am
I am learning about CDP (working on CCNA still), and I thought I understood it
well enough.. then I read (Sybex CCNA 5th) that you can
only get the IP address of directly connected devices.. does that imply that you
can get other info from remote devices with CDP? In my
home lab, I can't seem to, and at work where we have at least 12 routers and
several switches, we only get neighbor info also... So how,
if at all, can you get info of devices that are not directly connected (not
including devices connected through an off-brand switch).
Thank you!
Re: Basic CDP question..
none@anytime.net wrote:
All information you can get with CDP is from your directly connected
devices. Nothing from remote devices.
For example you can see your directly connected switch but not devices
behind the switch.
(Exception: It is possible to tunnel CDP packets thorough the switch...)
JV
OK.. Thanks JV!! I appreciate your help in clearing this up!
behind the switch.
JV
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » Problems using the extended ping command
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » Long time no see.
- — The site's Newest Thread. Posted in » CCTV, Alarms and other Physical Security
