New cable is always preferred, but extending your existing cables is also acceptable.
Usually it's just a question of budget and time (and conveniance).
If done correctly with high quality parts it will have minimum impact on the signal.
Since it is for yourself and you want it done right, new cabling is the way to go. :)
