Home Automation x10 basics--noob question
Subject Author Date
x10 basics--noob question T.B. 06-13-05
Posted by T.B. on June 13, 2005, 5:00 am
ok, i have a pull cord light above my kitchen sink that I need to replace
with a regular light fixture that needs to be controlled by a switch. the
problem is that I can't get into the wall to access the wiring to make the
switch work properly. somewhere along the way, someone told me that I
could overcome this problem by using an x10 switch module to control the new
light fixture.
so my question is: will x10 work for me in this application? if so, what
components will I need and how do they install? i have found this product
http://www.smarthome.com/2031.html but don't know if it is what I need. is
there something that will need to go on the light itself? i'm confused and
haven't really found any good websites that address my specific questions.
thanks in advance,
TB in Austin
Posted by brobin on June 13, 2005, 10:25 am
Need a bit more info please. Do I have this right? You have a light above
the sink that works now using a pull chain from the light fixture. So there
is power to the fixture. Is there a switch for that fixture already in place
but broken or no switch for the fixture anywhere, except for the pull chain?
If there's no wall switch now then you could use the following 3 items to
do what you want to do. These are all from www.x10.com:
http://www.x10.com/automation/lm15a_s.html This goes in the fixture. Screw
it into the bulb socket and scre the bulb into it.
http://www.x10.com/automation/ss13a_s.html This switch simply sticks on
the wall and can controll up to 3 lights with Dimming control.
http://www.x10.com/automation/tm751_s.html This plugs into any convenient
outlet and relays the signal from the switch to the fixture module.
> new
> light fixture.
> is
> and
> thanks in advance,
> TB in Austin
Posted by T.B. on June 13, 2005, 5:37 am
there
place
chain?
there is no wall switch for the light above the sink. only the pull
chain.
Screw
convenient
this looks like what i need. thanks for clearing that up.
replace
the
the
> > new
> > light fixture.
what
product
> > is
> > and
questions.
> > thanks in advance,
> > TB in Austin
Posted by ceedub on June 14, 2005, 12:57 am
> there
> place
> chain?
> chain.
>> to
> Screw
> convenient
> replace
> the
> the
>> > the
>> > new
>> > light fixture.
> what
> product
>> > need.
>> > is
>> > and
> questions.
>> > thanks in advance,
>> > TB in Austin
From what I gather, you need an inline module such as:
http://www.smarthome.com/2251ac.html
This could be mounted into the junction box above your current pullswitch
fixture. Below this, you would mount whatever standard light fixture you
wnat. Then to control this receiver, you need to have a transmitter
somewhere. X10 sells transmitters that look like wall switches. I don't know
much about them.
Craig
Posted by T.B. on June 14, 2005, 3:47 am
know
> much about them.
> Craig
if i did purchase this inline module and install it in the J Box, would
it just control the one fixture above the sink, or could I use it in the
future
to control other lights, etc?
Similar ThreadsPosted
Illiterate X-10 Question October 25, 2005, 6:39 pm
4 camera DVR question April 20, 2006, 9:54 am
X-10 Switch Question April 14, 2008, 10:11 pm
Zwave wiring question.. December 19, 2004, 9:44 pm
Wide Open Question(s) January 24, 2005, 12:22 am
x10 basics--noob question June 13, 2005, 5:00 am
Beggginer 3-way switch question.... September 22, 2005, 5:33 pm
Wiring question: POE Interference December 15, 2005, 9:13 am
Insteon/X10 USB controller question January 17, 2007, 8:37 pm
Active Home Question May 17, 2008, 5:48 pm
Porch light by remote question. May 2, 2005, 1:34 am
question about Elk M1 Gold alarm system November 6, 2006, 12:52 pm
Question on Remote Data Access January 2, 2007, 12:59 pm
Older Active Home (v 1.3) / DST Question February 26, 2007, 1:35 pm
Interior Of House Gas Shut Off Valves Question March 20, 2005, 10:52 am
