ADSL - Should I disconnect and reconnect?
Sep 11, 2004 1 Replies
Rick Wintjen
If you have a poor noise margin, you modem will negotiate down to find a more stable connection. It won't go the other way. If you can, query the modem from time to time (or run a speed test) to see if this is happening. If your connection speed degrades over time, restarting…
Is there any advantage in occasionally disconnecting your ADSL link and reconnecting in order to "freshen" the connection?
I keep my connection on all the time for days or even weeks on end although I do reboot the computer every day. Might my connection speed be improved if I ocassionally disconnect and reconnect?
If you have a poor noise margin, you modem will negotiate down to find a more stable connection. It won't go the other way. If you can, query the modem from time to time (or run a speed test) to see if this is happening. If your connection speed degrades over time, restarting the modem might bump it back up.
