Wifi security in Hotels?
Jul 03, 2009 23 Replies
Thank you, John
fundamentalism, fundamentally wrong.
Thanks for the suggestion
Yeah, looking for the outside air temp.
Thanks though
Thanks especially if the 'engineering' doesn't get too complex.
True, it is just getting the data on the LAN. Thanks had not considered this approach until you and others suggested it.
