Have the WRT54G version 4.......what install do I use...the enclosed CD......the quick install down load from Linksys...or the set up a home network provided my MS XP Pro......am confused......
Happy New Year to all.....
I'm probably not the best person to answer this question as I've never used or needed either the cdrom or downloaded install for the WRT54G. If you start with a WRT54G reset to defaults, then all you need to do is: 1. Connect all the wires, cables, connectors, and spagetti.…
Read the full replyHave the WRT54G version 4.......what install do I use...the enclosed CD......the quick install down load from Linksys...or the set up a home network provided my MS XP Pro......am confused......
"Mindy" hath wroth:
There are plenty of other things that might be useful to change in the router. However, that's the basics and neither the cdrom or the download cover anything more than the basics.
Use the CD that came with your wireless router. The reason many people install a router is to have multiple PCs connected to the internet without having to use one of the computers (Server) as a gateway to access the internet (Windows Internet Connection Sharing). With the router, each connected computer has independent access to the internet because the router is the gateway. Keep in mind that this is just a simple answer to your question.
Have HP desktop and notebook both XP , desktop Pro and notebook Home....hooking to Earthlink DSL modem.....
