I've a D-Link DWL-650 PCMCIA WiFi card.
There is this connector:
What kind of connector is? I'm looking for a direct adapter to RP-SMA, instead of use a pigtail.
THANKS!
Fairly nice photos. Hirose MS-156 series: is NOT a u-FL connector. You don't want to know the price of their SMA adapter. Also see: | additional clues and hints. It's a common guestion. Please note that this is a test connector and was not intended for user interace. It will…
Read the full replyI've a D-Link DWL-650 PCMCIA WiFi card.
THANKS!
Fairly nice photos.
Also see: |
Please note that this is a test connector and was not intended for user interace. It will not survive many connect/disconnect cycles.
"Jeff Liebermann" ha scritto nel messaggio news: snipped-for-privacy@4ax.com...
Thanks! C5050 Olympus in a few of seconds...
Thank you very much.
LOL! Thanks again: I'll use a simple pigtail soldered on the board.
hard to tell the difference between them these days,but its a connector and a switch in one package. note the two small pads on either side of the input trace
the outlined area around J3 could accept another jack of your choice or a pigtail,just reorient c127 to feed it
