What Feed antenna for Dish?
Jun 25, 2008 2 Replies
amdx
Never mind, it looks like it is just the efficiency of the feed that maters. The dish diameter, proper geometry and alignment that matter most. Mike
If you have a dish of (d) diameter, does it matter what type of feed antenna you use? Monopole, dipole, biquad, patch, will the gain change with a different feed antenna? Mike
See article on the subject at:
The type doesn't matter. What's important is the illumination angle. If the feed sprays RF in directions other than at the dish, you lose some transmit gain. If the feed is too narrow, and only illuminates part of the dish, then you lose both transmit and receive gain.
The bad news is that it's almost impossible to get all of the RF to hit the dish. The feed pattern is not going to have an abrupt transition at the edges (edge taper). Instead, it just tapers off, like any other antenna pattern. The result is that a dish will never have 100.0% efficiency. At best, you'll see about 50% efficiency. See:
for details.
