I have two WRT54GS talking though a 800-900 foot distance through trees. There's no other way. I have a 15 db Yagi on one end, and will be purchasing something similar for the second end. Right now, I'm seeing -91 (+-1 or 2 points) signal rhough the DD-WRT wireless status, This is with the transmit power turned up from 28 mw to 200 mw (yes two hundred).
Has anyone else had the power turned up this high? If so, how long can I expect these boxes to last?
Can anyone recomend a nice flat 15-ish db antenna I can mount on the second box. I'd prefer flat, as a yagi would be an eye sore.
Thanks. Obviously you are an electrical engineer - officially orotherwise....
J
Jeff Liebermann
snipped-for-privacy@gmail.com hath wroth:
Yep. Two of my friends locally. Lasted about 2 weeks and blew. I have one of these V4 routers but haven't had time (or inspiration) to do an autopsy.
Oh, any one of these will work:
1ft away from the antenna, the RF exposure is 0.5 mw/cm^2. The maximum permissible exposure for an uncontrolled environment is
1.0 mw/cm^2. You're safe to about 0.8ft away from the antenna.
J
jamessmalljr
So if I move from the standard antenna to a 14 db flat panel on the remaining 'stock' linksys, will that give me more than a 10db improvement? What's the rating of the stock antenna?
If so, then will I get equivallently the same 'reception/transmission' quality if I reduce the transmission power from 200 mw on both ends to just 20 (rather, 28 mw, the stock).
--Now, I'm still getting fade during the day. How high can I put the transmitters for general use? 40 mw? 48 mw? 50 mw?
J
John Navas
It should -- the gain of a stock "rubber ducky" antenna is about 2 dBi.
As an alternative, see
J
Jeff Liebermann
The stock antenna is essentially a coaxial vertical dipole antenna. Gain is about 2dBi. A 14dBi flat panel will give a maximum of 12dB gain over the stock antenna. However, don't forget to subtract coax cable and connector losses from the 12dB.
Most non-reflector antennas have the same gain in transmit and receive. 14dBi gain in transmit and receive. However, if you use a dish, the gain is somewhat different betweeen transmit and receive depending on how well the feed illuminates the dish surface. In general, the transmit gain of a dish is slightly less than the receive gain because the feed's tendency to "overspray" the dish.
Going from 200mw to 20mw is a factor of 10. In dB, that's a change of: dB = 10 * log(10) = 10dB
Are you sure it's fade and not inteference from other networks that only operate during the day?
I really don't know. My guess is 50-100mw max. I know that 250mw will eventually blow up the transmitter, but I don't know exactly what power is safe. There's also the not so minor issue of FCC type certification. I'll pass. Anyway, going from 35mw to 100mw is wasted. It's only dB = 10 * log (100/35) = 4.6dB I suggest you work on the antenna part of the puzzle and leave the power alone.
Report Content
ASAP.
