What [automated] apps (or techniques) do you use to ensure radio transceivers are off?
Nov 24, 2022 Last reply: 3 years ago 44 Replies
I found this by searching which says it can be done but that's old,
On my recent model phone is a setting called "Turn on Wi-Fi automatically" which is off by default.
It's in Settings, Connections, Wi-Fi, top right Advanced, Intelligent Wi-Fi, and then Turn on Wi-Fi automatically
Below that there is also an option to look at your "Wi-Fi control history" which says "View apps that have turned Wi-Fi on or off recently" so it sure looks like apps can turn on wifi automatically and then shut them off.
I don't see the trolls but on the topic I could use an app that automatically turns off the power to the wifi of the phone whenever the access point is disconnected for a period of minutes (maybe 10 minutes).
How would it ever then come back on?
I don't know about you, but I want my phone to automatically connect to WiFi wherever I go.
your scripts are broken. frank didn't say that.
try a mirror.
that type of functionality is built into ios and does not need an app.
