Testing Equipment for 802.11 b/g and Ethernet
May 30, 2006 1 Replies
I was wondering if there are some good testing equipments available for
802.11 b/g and Ethernet for testing/managing/fault diagnosis of a WLAN and LAN . It would be good if i can get a link directly to the vendor
thanks
snipped-for-privacy@gmail.com hath wroth:
Sure, but you won't like the prices. Start here: |
few "testers" will do both ethernet and wireless. Methinks it would be helful if you would supply some details as to what you expect to accomplish with this test equipment. Also, fault detection and management are usually done with SNMP based software (e.g. HP OpenView). Are you really looking for a duz it all tester that will literally test anything in networks (and also manage it)?
