Satori and WRT54G and also Range Extender--does it work?
Feb 27, 2005 1 Replies
Ook
The Linksys Range Extender is an overpriced piece of crap. Avoid it at all costs. If you bought one, return it to where you got it from. If you want to extend the range of your network, get a second WRT54G, and use satori or better yet, Alchemy because Satori is at the end of…
  1. Have a new Linksys WRT54G router and wonder if the Satori firmware is all it is cracked up to be in terms of boosting power without skewing the signal or corrupting connections?
  1. Also can the WRT54G work with a Range Extender from Linksys?
Thanks so much for optimal configs or advice. I am a newbie at this. Been trying to read as much as I can.
Sincerely Patty
If you want to extend the range of your network, get a second WRT54G, and use satori or better yet, Alchemy because Satori is at the end of it's lifecycle. By enabling WDS, you can use the second WRT54G to extend the range of your network wirelessly, IE you do not need to run a cable to the second WRT54G. I know this because it is exactly what I am doing, and it works very well.
