Jolly Roger wrote on 30 May 2024 21:36:46 GMT :
And yet, it's not.
Which proves beyond question what you Apple zealots don't understand.
*All you wish to do is defend Apple's vulnerabilities to the death.*See technical proof in the sig proving sheer ignorance of the zealots.
-- Note 1: The hidden broadcast won't hide the BSSID from a seasoned attacker (such as a Google or Apple tracking vehicle - depending on how its code is written); but the mere act of hiding the SSID broadcast packet has been proven to prevent the normal users' device (i.e., mobile phones) from uploading your BSSID using the typical software that we are speaking about.
Note 2: Since the Apple religious zealots act only out of franctic desperation to make excuses for all Apple's vulnerabilities, it should be noted that an intelligent person knows the difference between the upload of the BSSID (which is a first-order issue) vs the deletion of the BSSID from the Internet databases (which requires second-order software processing).
Note 3: There's no way the Apple religious zealots will understand the two notes above, but for the intelligent people reading this thread, it should be noted that if you do hide your broadcast packets, then you often might want to set your client (such as a phone) to "remember" and "reconnect"; but this has other issues - where the Apple zealots won't understand but adults might understand that the "remember" is fine (unless you're worried about your phone being stolen) but the "automatic reconnect" should be turned off because that setting causes the phone to seek out the named AP.
