I have a Buffalo Airstation (WZR-RS-G54) and am using dynDNS. Two problems occur:
1) As long as at least one PC behind the router is on, the automatic DynDNS update works. BUT: I can remote manage the router by connecting to its IP-address (in numbers), not using the DynDNS-address. (I can remote connect to the PC using the DynDNS-address, though, so it gets resolved correctly.)
2) When I turn all PCs behind the router, DynDNS updates stop, ebven though they shouldn't. The router has a "wake up" feature for the PCs, but I can't use it because I can't connect to thze router. Buffalo says, the router should be able to do this, but it's not.
If anybody has any suggestions what to try next, I'd very much appreciate it!
Thanks, Ulrich
