Newbie wifi question
Oct 15, 2005 1 Replies
I bought a 3com wifi card to use in an old pentium 2 i had kicking around (98se) The card is installed and funtioning ok but I cant access the internet. The tcp/ip configuration is set up same same as for my lan card wich works fine. Example I was in a spot last night which showed
80%+ connectivity on an open network but when i launch the browser i get nothing, nor can i see the network in network neighborhood. Any help would be greatly appreciated.
Thanks
Poe
Are you using a software firewall? Check that the router Wireless IP address range is allowed.
Also check through the router to see what computer names it can see.
