newbie question on speed
Jan 31, 2006 0 Replies
I moved my computer and rather than setting up a long cable across the room I set up a wireless connection instead, Trendnet 802.11g router and USB wireless adapter. I checked my speed with toast.net - while before I would get 4.5 ~ 5 Mb/s (?) I now get around 2.5 Mb. Is that normal? If other brands are better, should I upgrade the wireless adapter, or the router, or both?
thanks in advance!
