Netstumbler: GPS Listening But No Latitude/Longitude.
Jan 16, 2007 1 Replies
I am using Netstumbler on Windows XP with an EverMore GM-R700 GPS Receiver.
I 99% sure that I have all of the settings correct as follows:
Protocol: NMEA 0183
9600 Baud rate
8 data bits
1 stop bit No parity Port: Com 4
I run Netstumbler and I see active Access Points etc, and it reports 'GPS: Listening' but it never returns any latitude / longitude.
This is the first time I've used the GPS Receiver and I understand the 'cold start' concept but I've left it running for WAY longer than I should have to and... nothing.
What might I be doing wrong? Any suggestions greatly appreciated. Thanks in advance.
Ahhhh, it would appear the baud rate was wrong. Changing it to 4800 seemed to do the trick.
Problem solved.
