need wireless router recommendation
Nov 21, 2004 9 Replies
Jump to replies (9)
I'm using a Netgear FWG114P, rock solid!
Bill Crocker
Short of a Cisco router, what's a good wireless router for a home user? I have a Netgear WGT624 but it is annoying that it drops the internet connection after about a minute of being connected for administration. I've had DHCP issues with it also. It's mostly an annoyance but it makes me wonder about it's reliability......
So, I'm shopping. :-D
Cisco owns LinkSys.
Bill Crocker
I gather you don't like Cisco, but my Linksys WRT54FG works fine.
If I could afford a Cisco router and if I was running a business I'd consider buying one.
Yes, but that does not mean that buying a Linksys router gives you Cisco quality. You get the same low end consumer grade router with Cisco's name on it.
As noted, linksys is Cisco. After rebate the WRT54G v.2 cost abot $60. There are higher and, I think, lower, priced models.
I have a netgear WGT634U.
I had a problem to start with. Wire connections worked, but no wireless (radio).
They sent me a new one. A complete new one, in the box, with all of the parts.
My next problem was with my laptop. This was my learning how to.
After I got that figured out, I have no problems. It works when I want it to. I use the wireless for the laptop so I am not limited to the "computer" room.
I use WPA security and when I am not using the laptop, I turn off the radio. This is the highest form of security.
I have no known problems with drop out or loosing the connection while in admin mode.
OT: I was in Virginia this last week. The hotel had wireless service. I only found it in the lobby. It was slower than molasses in January. My laptop said I had and excellent connection, but. My home service from RR broadband has spoiled me.
I like Linksys, except for my BEFVP41, which doesn't work, and is apparently unsupported.
