Maximum IP range of router
Dec 12, 2006 10 Replies
Jump to replies (10)
I have a LinkSys Wireless G Broadband Router with SpeedBooster, WRT54GS, Firmware version 4.70.6. How do I find out the maximum IP address that the router can assign a machine on my local area network?
Thanks, - Dave
I believe the DHCP on that router provides 50 addresses, from 192.168.1.100 through 149
Linksys normally provides that info ont the status/localnetwork page of the router setup.
I found the setting. RBM was correct. The starting address is
192.168.1.100, up to 50 IP addresses.
So if I statically assign my Linux machine (which sits behind this router) 192.168.1.151, will I continue to be able to route to there?
Thanks, - Dave
Pen wrote:
You should be able to assign static addresses from 192.168.1.2 through 99 and then from 151 to the subnet mask 255, (I believe)
If the router is assigned 192.168.1.1, and you set the DHCP pool to start at 192.168.1.2, then you can have 254 assigned address, but...according to
, the GS can only realistically support up to 100 computers.
The usable range is from 192.168.1.2 to 192.168.1.254.
192.168.1.1 is reserved for the router, and you cannot use 192.168.1.0 and 192.168.1.255
The reason the DHCP range default is only 50 - is so you use some addresses as static addresses (like servers, printers, etc).
If you don't want to use, or don't need to use static ip addresses - you can set the DHCP range from 192.168.1.2 to 192.168.1.254
Correct.
Personally, I use a "schema" for my static ip addresses:
Servers start at 192.168.1.10 to 192.168.1.29
Printers start at 192.168.1.30 to 192.168.1.49
Access points start at 192.168.1.50 to 192.168.1.69
Other tcpip appliances network drives, etc start at 192.168.1.70 to
192.168.1.89
and I maintain a hosts files and distribute this to all hosts.
decaturtxcowboy hath wroth:
Actually, it's less than 100 when tested. See:
select "Maximum Simultanous Connections" from the pull down menu thing. WRT54Gv5 = 8 connections WRT54GL (same as v4) = 64 connections.
When NAT routing behind a single IP address it can really be limited unless there's an internal proxy handling the HTTP requests. Otherwise the router runs out of available ports. This comes as a rude surprise when someone in a medium-sized office tries to cheap out and use a SoHo router behind a single IP address. Not that it applies to this thread however.
Are you not the administrator of this box? If not, then don't go setting IP addresses without consulting with the admin. You may end up stepping on someone else's address. Pings are not a reliable way to check for available addresses, as many firewall products are (rightly) configured to not answer ICMP pings.
